Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#851682 05/15/2012 3:30 PM
1950 Chevy 3100.
Recently had gauges rebuilt. All functioning except speedo. Gauge operates but needle does not move above 10mph.
I was told that speedo drive gear in transmission must be replaced.
Can this be done without removing tranny?
Kurt
First I would check to see if that is what it is. Disconnect the speed o cable at the trans. Use a variable speed drill and spin the cable checking the needle on the speedometer. If the speedometer works fine, it is the gear in the transmission. If it doesn't then its the speedometer.
As for the gear replacement, I've replaced them on newer transmissions. Is yours a 3 or 4 speed?
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
DMGfifty #851703 05/15/2012 5:14 PM
Thanks David.
Speedo works fine.
Transmission is a 3 speed.
