3 members (BC59, cmayna, Peggy M),
144
Mod | | | Forums66 Topics128,095 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I have several old vehicles with lots of grease fittings (1952 Chevy 3100, 1960 Massey Ferguson 50, etc). I'm having a terrible time getting a nozzle for my grease gun that works right. My old nozzle is too loose so a lot grease squirts out around the fitting. The new nozzle(s) I bought fits so snugly, I sometimes can't get them off. Last week I got 3 of the four fittings on my kingpins greased without too much tugging, but on the fourth fitting (which was a new fitting I had recently replaced), I could not pull the nozzle off the fitting. After about ten minutes of pulling by hand, I gave up and unscrewed the fitting with the nozzle still attached. Then I tried putting the nozzle in a vise and pulling the fitting out with vise grips. All that did was break the fitting, and left part of it still in the nozzle. Is there a particular brand of grease nozzle that works better than others (I got mine from NAPA), or is there a trick to breaking in a new nozzle?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Interesting problem. My old Sears gun is loose too, so I usually hold the nozzle tight by hand when I pump the grease. That seems to work. I wonder with the large amount of metric stuff now,if that's the reason the new one is too tight.
Drew
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | MY old grease gun has a hose and nozzle and the nozzle has a knurled adjustment "collar" that I can turn to tighten or loosen the fit...
Professional Novice
| | | | | Joined: Aug 2006 Posts: 18 New Guy | | New Guy Joined: Aug 2006 Posts: 18 | Hi Frank50; Do you remember where you got the grease gun & nozzle from and does it have a brand name on it? Thanks Roger. | | | | | Joined: Jan 2009 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 47 | I think that Lincoln has a fitting that is adjustable for the grease zerks problem that you are talking about. At least the ones that came on my 2 Lincoln grease guns have them. I have 2 seperate guns because 1 is used on aircraft and the other is on vehicles. Good luck
Ed | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Sorry roge. No name on it that I can see. I've had it about 30 years and may have bought it at K-mart...
Professional Novice
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hi guys - My post is probably more for newbees like me ... I ran across this thread when I was trying to figure out how to use my new $15 Harbor Freight grease gun. Never had a grease gun in my hand before; didn't even know how to load it with grease - and now I'm an expert! (HA) Anyway, one of the reviewers of the HF gun wrote "Grease Gun 101" instructions for newbees. He's a little condescending, but the info worked for me. Click on "Customer Reviews." The review by "AJ - Professional Mechanic & PT Farmer" is about half way down the reviewers' page. > Grease Gun 101
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Are you trying to pull the grease gun straight off the fitting? They won't come off straight. Otherwise they would blow off when you put pressure on them. Try wiggling the the nozzle to the side and it will come off. If you have a fitting in a tight place such as a U-joint, use a needle nozzle. http://www.thetoolwarehouse.net/p-16306-lincoln-lubrication-82784.aspx | | |
