9 members (Oswald, Bill Hanlon, Rosco, Southerntruck, Bungeemaster, 2-Ton, Pre '68 Dave, TUTS 59, 1 invisible),
253
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,288 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | My 3/4 ton panel truck came to me with many parts in boxes. I'm currently trying to configure the master cylinder/brake pedal setup. The MC is mounted on the frame, with the plunger pointing to the rear (unlike my 37 1/2 ton, which is turned the other direction). Behind it on the frame is mounted a bracket that swivels, which is connected to the plunger on the MC. The brake pedal is in a box. I can't seem to figure out how the pedal is mounted and how it actuates the brakes. It's obviously a different system from the 1/2 and passenger car.
From studying the parts book, it appears the most of the parts for the 3/4 ton, 1 ton, and 1 1/2 are the same for both 1937 and 1938 trucks. I've looked in the shop manual, construction manual, and parts book, but I can't locate a schematic or picture of this setup. Does anyone know where I can find a schematic of this brake system or have a picture that can be posted or sent to me? I'd greatly appreciate any help (what part/s am I missing or need to locate in order to mount the pedal, etc.?).
Thanks very much.
Jim | | | | | Joined: Sep 2010 Posts: 1,736 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,736 | jmmmn37, I just went through this same set up on my '38 1 ton. I updated my brakes to a dual line m/c. Here is photo of how i installed my master cylinder and the actuating rod. master cylinder If you are using the original bell housing the pedals mount to it. If you have changed to a newer one you will have to fabricate a bracket to mount the pedals to. This is what I did. new bracket
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Jim, If you PM me I have a couple of shots of the master cylinder still mounted on the frame of a 37 big truck with the cab removed. Shows master cylinder and mount very well but not so much on the pedal mount.
Evan
| | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | Wayne,
This is awesome--thanks so much. I didn't figure on the long rod from the end of the lever up to the pedal on the bellhousing. I think I might still have the rod in one of those boxes--if not, easy enough to fabricate from your excellent picture. I'm keeping it all original, so it should mount to the bellhousing without too much trouble.
Thanks again--much appreciated!
Jim
P.S. Is your 1 ton a pickup, or another configuration? | | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | Evan,
Thanks--I have the master cylinder still mounted on the frame; so I know how that goes--as I replied to Wayne, I didn't realize the way the long rod worked there. Thanks so much for your help.
Yours,
Jim | | | | | Joined: Sep 2010 Posts: 1,736 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,736 | Yes my truck is (was) a 1 ton. I've changed the axles to 1/2 ton. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
