Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (TUTS 59, DES57, BLUEMEANIE, Peggy M, Waveski, 55shaker, Joe W), 532 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#850529 05/10/2012 11:26 PM
My '48 came with 15" 6 lug aluminum wheels and fairly wide radials. I'd like to put steel wheels with factory style hubcaps on it. I think the narrower wheels and tires will look good and make steering easier. I've been told that 16" 6 lug steel wheels are hard to come by. Will 15" steel wheels clear the brake drums? Will the repro factory style hubcaps fit on 15" wheels?
mojoel, yes, narrower tires will make steering easier. 16" wheels are common, but a lot of them suffer from rust (at least in the Southeast U.S.) Repros are available. Be aware, some will take original hubcaps, and some only will take the special caps they sell. If you have stock brake drums, most any 6 lug will bolt up. Offsets will be different, too. If you have front disc brakes, stock rims will probably not work. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.151s Queries: 14 (0.078s) Memory: 0.5921 MB (Peak: 0.6237 MB) Data Comp: Zlib Server Time: 2025-09-22 17:05:28 UTC
Valid HTML 5 and Valid CSS
