0 members (),
123
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | I picked up a 1959 C3600 about 10 years ago and am about to start the long process of restoring it. (Can't wait!) I'm puzzled by the jar in my engine compartment. There's nothing in the Chevy repair manual on this thing. Has anyone ever seen this before? What is is and what do I need to do to restore it? [url=[IMG] http://i1265.photobucket.com/albums/jj512/bestvcdadever/Truck1.jpg Thanks, Rick -
Proud of my taskforce! 1959 3600 long-bed. the ultimate work truck!
Rick Restivo Valley Center, CA.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That looks like a windshield washer bottle. I am guessing that there is a vacuum operated pump inside. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Rick, there was a post recently where someone supplied some info on how those worked
yes, it's a washer setup, which won't be in the manual because it was an optional accessory and not real common .... looks complete enough that you should be able to cipher things out - and rather than a pump in the bottle, I believe there should be one hose that connects to that extra fitting on the manifold so it runs off engine vacuum like the vacuum wipers
and for your truck model designation - leave off the "C", that wasn't used until the 60's, it's just a 3600
Bill | | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | Thanks for the replies. Great to know what it is. I'll search the forums looking for the info on these pumps. It will give me a good excuse to read all the posts on this site. As far as the "C" in front of the 3600, call it a rookie mistake. won't happen again. Rick -
