1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#84958 04/29/2003 4:31 PM
I have been reading past posts and have a question. What is a DA plug? Does DA stand for something? Thanks Just trying to become more knowlegable!!
#84959 04/29/2003 6:59 PM
It's the Delco Alternator plug, it connects to the field and regulator terminals on a delco internally regulated alternator. You can also use spade lugs for this.
Paint & Body Shop moderator
#84960 04/29/2003 8:18 PM
To add a little to what 4onthefloor said;
If your converting to 12 volts, the DA Plug, also eliminates the need for the stock voltage regulator up on your fire wall.
The wire that went to the Battery terminal on the voltage regulator, now attaches to the alternator and the 6 volt regulator and the other wires attached to it, no longer need to be used.
I just converted my truck using this method. Note, the wires I no longer needed to use; I did keep in the harness, just in case I or someone else ever wanted to go back to completely stock.
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
#84961 04/30/2003 2:30 AM
When I converted my truck to 12 volts I thought I would save myself some money and not pay what some of the vendors wanted for a "D.A. plug". So I went to Pep Boys and bought a delco alternator plug. Got it all wire up, but when I went to turn off the truck it wouldnt shut off with the key.
I came to find out that the aftermarket D.A. plug that the vendors sell has some kind of diode wired into the unit that allowed me to shut off my truck with the key.
#84962 05/02/2003 12:38 AM
You don't have to do that if you wire up your ignition switch properly. There are three terminals on the stock AD switch, they all get shorted together when you turn the key. Just make sure that the battery and alternator are on the same post and that the ignition system is on one by itself. I run my alternator with no DA plug at all, just insulated spade lugs on the wires to the pins in the alternator.
