6 members (Millenimech, Gib70, Hotrod Lincoln, Steelonsteel, Gray_Ghost, 1 invisible), 149 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#84930 01/12/2002 5:21 AM
Hi,
Can someone suggest the cleanest, quickest method for wiring up a pair of fog lights?
Jim
#84931 01/12/2002 8:01 AM
Use a relay kit, from the parts store.
Quick!!
Easy!!
OR wire them with your own relay/wire.
Whatever you do USE a relay!!!!!!!
[img]http://www.stovebolt.com/bboard/ubb/eek.gif[/img]
http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/foglites.htm
[img]http://www.stovebolt.com/bboard/ubb/biggrin.gif[/img] [img]http://www.stovebolt.com/bboard/ubb/biggrin.gif[/img]
[ 01-12-2002: Message edited by: redshiba ]
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#84932 01/13/2002 2:46 PM
Boy there is some great information the Suburban Owner's link above. Very good stuff! Thanks!
#84933 01/14/2002 6:09 AM
How could I use a relay for my after market a/c, from Vintage Air. ITs a 65 chevy street truck, 350-350 turbo, Everytime I turn it on (fan, and commpressor) the drag on the voltameter goes down to 8-9 volts. then turn it off and everything goes back to 13.5 volts. thanks, kool 65
#84934 01/14/2002 7:25 AM
I am no expert on this but a relay will not the AMP draw on your alternator.
It sounds like you need a better / higher AMP alternator??
When you turn on your A/C your alternator is not able to keep up with all the demand.
[img]http://www.stovebolt.com/bboard/ubb/frown.gif[/img]
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#84935 01/15/2002 3:30 AM
Kool65, you have a problem either in you a/c or your alternator or generator/voltage regulator is bad. Need to hook up an ampmeter and see where the problem is.
Fred
52 3600
69 C-10
