| | | Forums66 Topics128,267 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84930 01/12/2002 5:21 AM | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | Hi,
Can someone suggest the cleanest, quickest method for wiring up a pair of fog lights?
Jim | | |
#84931 01/12/2002 8:01 AM | Joined: Feb 2000 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 57 |
Kelly 1951 Chevy 3100 1967 RS/SS Camaro
#84932 01/13/2002 2:46 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Boy there is some great information the Suburban Owner's link above. Very good stuff! Thanks! | | |
#84933 01/14/2002 6:09 AM | Joined: Dec 2000 Posts: 9 Member | | Member Joined: Dec 2000 Posts: 9 | How could I use a relay for my after market a/c, from Vintage Air. ITs a 65 chevy street truck, 350-350 turbo, Everytime I turn it on (fan, and commpressor) the drag on the voltameter goes down to 8-9 volts. then turn it off and everything goes back to 13.5 volts. thanks, kool 65 | | |
#84934 01/14/2002 7:25 AM | Joined: Feb 2000 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 57 | I am no expert on this but a relay will not the AMP draw on your alternator. It sounds like you need a better / higher AMP alternator?? When you turn on your A/C your alternator is not able to keep up with all the demand. [img] http://www.stovebolt.com/bboard/ubb/frown.gif[/img]
#84935 01/15/2002 3:30 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Kool65, you have a problem either in you a/c or your alternator or generator/voltage regulator is bad. Need to hook up an ampmeter and see where the problem is.
Fred 52 3600 69 C-10
