1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | I rebuilt my 228 several years ago, but have driven it very little since. It just never seemed to run as good as before. I started it for the first time in a couple of years last night and it just seemed to be running too rich and wouldn't smooth out. I am confident that the carb is in good shape. I just shut it down...disappointed as usual. I notice that the area just below the carb is smoking when I shut it down and the paint is burnt to a crisp on the manifold in that area. Shortly after I did the rebuild, the muffler/exhaust system got loud. I am wondering if maybe my muffler collapsed and back-pressure is causing the rich running condition, or is the heat riser valve not rotating. Any ideas would be appreciated. I really want the ole truck to run good again so I can de-stress when I drive it and not re-stress. Thanks, Jim. | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Jim, I have one of those too. I suggest you drop the exhaust pipe at the manifold and make sure you don't lose the little doughnut that is usually in that flange. Then start it up and see how it runs. That will answer your possibility of an exhaust system constriction. If this doesn't get it running its time to pull both the intake and exhaust manifold and see what may be in one of those intake or exhaust passages. It sure sounds like there is blockage up near the engine block in an exhaust port with the heat description you give. Normbc9 | | |
