| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | I have a 41 chev pu 1/2 ton with what I believe is the orig. push starter. From what I'v read in 41 they started using a reverse polarity switch but mine does'nt have any holes in the top of the starter for it was wondering if I should go without it? | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | What does a reverse polarity switch do? Thanks,
Kurt | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, the reverse polarity switch was a device the engineers came up with that was mounted on the starter, everytime you started the truck it reversed the polarity of the electricity flowing through the points. The theory was that this would cut down on metal transfer between the fixed and movable points, better condensor technology made these parts unnecessary, and they were discontinued after a couple of years. So don't bother putting one on in the first place, hope that helps. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | 3B is correct and Im not in front of my Delco books at present but pretty sure they were only used in like 46-47, somewhere in there. Not a necessary part unless your doing a 100% show quality restoration for that particular year model and even at that most folks dont know what they are or if they are correct or not. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Wow, I've had old Chevys for 40+ years, and never heard of that before. Gotta love this forum, I learn something every day.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
