2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#846809 04/26/2012 3:36 PM
When I let the truck sit a few days, I get a big puddle of ATF underneath. This is actually the second transmission I have had in the truck. Same problem.I have had the transmission out of it several times, quite frankly I would like to fix it once and for all. Is there something I am doing to cause this? Is there a common cure?
That's a pretty common problem with the TH 350. The torque converter is draining back into the case, and raising the fluid level above the centerline of the driveshaft yoke. There's a tiny hole in the plug in the end of the yoke just ahead of the universal joint to prevent air pressure buildup as the yoke slides in and out. Fluid will leak out of the hole if the level gets too high. The simple fix is to pull the yoke off the U joint and weld up the hole. If you want to do it "right", drop the valve body off the transmission and find out why the converter anti-drainback valve isn't sealing. That's a BIG job with the transmission in the vehicle!
Thanks Hotrod L. I have the same problem and appreciate the info.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
That is awesome info. I'm for the simple fix.
