5 members (TUTS 59, 32Fordpuchoptop, panel fan, UtahYork, Otto Skorzeny), 68 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#846352 04/24/2012 10:02 PM
57 3100. I can't remember if there is a bolt that secures the lower rear of the front fender (on the outer skin) to the fire wall. Got the brace and the inner fender (at the fire wall) secured but have a bad knock with the lower part of the fender on both sides of the truck. It can be moved easily by hand. Looked at it. One side has a bracket and an unthreaded hole, The other side has hole and no bracket. Been off so long I cant remember. Help, please.
Are you referring to this attachment point?
It isn't real clear where this is located from the photo but it shows the placement of the nut.
attachment lower rear of front fender
Give me ambiguity
or give me something else
CASO #846358 04/24/2012 10:26 PM
Yep. I thought so. Gonna have to do some fabricating. Thank you for the picture.
