10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84589 10/23/2007 1:21 AM | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I'm using a later model 350 in a 59 frame. The exhaust manifold hits the steering box. I bought a set of center dump block hugger headers today, and these seem to be riding awfully close to the steering box. Mabey I don't have the engine far enough forward, or do I need a different set of headers? I know this has got to fit somehow. What say you guys? | | |
#84590 10/23/2007 4:25 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy martinmikey, V8s were an option on Chevy trucks from 55b to now, so you must have an engine positioning problem. Are you using any of the stock mounting locations? | | |
#84591 10/23/2007 4:50 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the usual modern manifolds on 350's don't work - the V8 in the TF trucks had the rams horn manifolds [center dump] - they're this close to the box and work fine Bill | | |
#84592 10/25/2007 1:25 AM | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | ALRIGHT, I stopped at a local salvage yard tonight and bought a pair of rams horn manifolds for 40.00 bucks, went to the barn to try em out, their going to work fine. Also found the v-belt pullys I needed, and a firewall power brake booster with duel master cylinder for $20.00. Bill thanks for that photo, it helped alot. Pretty good night so far.
Mike | | |
