thanks for all the help truble shotting the leak ,only ran whith full choke and ran bad.those who said carb ,main jet needs cleaning where right on.i rebuit the carb runs good. it hard to belive those particalls got past the filter, the bowl was verry clean.i replased the gas tank .the carb only had about 400 miles on it ,so you asume that was not the problem.thanks again
