0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84525 10/20/2007 4:59 PM | Joined: Sep 2007 Posts: 24 Apprentice | | Apprentice Joined: Sep 2007 Posts: 24 | Are there any gaskets, o-rings I need to correctly install the distributor? thanks | | |
#84526 10/20/2007 5:42 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bobshollow,
I think the general consensus is there are NO o-rings or gaskets installed beneath the distributor.
Stuart | | |
#84527 10/20/2007 5:51 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with Stuart. The 1947-54 Chevrolet Truck Shop Manuals and the 1947-54 GMC Maintenance Manual (which has a full page diagram of the distributor, with all parts labeled) do not make any mention of a distributor gasket, seal, or o-ring. There is no distributor gasket, seal, or o-ring list in a Master Parts Catalog (until 1957, for a V-8).
However, some people have posted that there was an o-ring. | | |
#84528 10/21/2007 7:27 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can't use an o-ring, the distributor needs to be able to rotate in the block as the vacuum advance does its thing.
#84529 10/21/2007 7:26 PM | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I was wondering if that might be a secondary reason for the grease in the grease cup, to keep oil from seeping out of the distributor mounting hole :confused_smile: Ed | | |
#84530 10/23/2007 1:12 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | when i bought the mini hei it came with an o-ring,,,,,,,,,,,,i used it.  | | |
#84531 10/23/2007 1:32 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Darin; It's o.k. to use the o-ring that came with your HEI, the vacuum advance is internal on the dizzy, the body doesn't rotate. I used it too, it stopped a pesky oil leak the old dizzy had. Yet another reason to go mini-HEI?? | | |
