| | | Forums66 Topics128,127 Posts1,056,678 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84489 10/18/2007 8:57 PM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I've looked at a few topics and can't seem to get the questions answered on this as of yet. I've been told by all my friends (who like me) that I should change the single master cylinder brake setup I have on the '60 GMC to a dual cylinder setup. As I understand it this would seperate the front and rear brake system into 2 different sets of lines so that if one wheel cyclinder fails, I would not lose brakes to all 4 wheels. Sounds like a great idea! I will "assume" that this will require a valve of some sort to send differents amounts of pressure to the brake systems. However, I do not know what to ask for in a dual master cylinder or what year. Or any other parts for that matter. I read "Cletis's" write up, http://www.stovebolt.com/techtips/master_cylinder/index.html on a change over but am unsure if this can be done on my '60 GMC. Has any of the members made the change and can you give some pointers? Thanks Jake | | |
#84490 10/18/2007 9:13 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Classic Performance Products carries a large inventory of brake upgrades for your 60 GMC. Their bolt-on dual MC with booster comes with a proportioning valve built in. http://www.classicperform.com/6092chevtrk.htm
~Jim
#84491 10/19/2007 2:32 AM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thanks I'll give them a call tommorrow, I see the kits but they state Disc/Drum, Not Drum/Drum. I don't know if they make a differance.
Jake | | |
#84492 10/19/2007 2:47 AM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Jake - If you still have drum brakes on all four wheels, no valve of any kind is needed. Get a new M/C with the same bore as your existing one & it'll have the same stroke & pedal 'feel' when you stop. Your local NAPA can find one in their paper catalog. A bit of fab. work & you can make a adapter bracket to mount it on your truck. Make a pushrod of the proper length & get some new lines & re-plumb it to split the front & rear & you're done. Doug | | |
#84493 10/19/2007 3:15 AM | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | Jake, I concur with Doug. Granted, the 6400 I have is 7 years older than your truck, but it's still got 4 corner drums and I didn't have to install a proportioning valve of any kind. We wound up taking the power brake system off an 81 1-ton Chevy Suburban and fabricating a bracket for it to mount it under the cab and we just plumbed new lines and ran them. It was nice because the truck originally had a hydrovac and the M/C was a power unit, so it still stops extremely well. It was definitely worth the minor hassle. -Jake Schaeffer | | |
#84494 10/19/2007 2:36 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The purpose of the proportioning valve is to engage the rear brakes before the front. This valve should be part of the MC on a dual system. I assume it would be beneficial on drum/drum systems. I don't know if the 60 GMC had a booster ( if I remember correctly, they were beginning to be installed in some vehicles about that time tho my 1960 Ford truck didn't have one) but I would guess you would want one.
~Jim
#84495 10/19/2007 2:38 PM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Big Chevy,
No it did not come with a booster and I'm at a lost as to what to ask for. I'll stop by NAPA and speak to one the old timers and explain the situation. | | |
#84496 10/19/2007 7:12 PM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Ok, I called CCP (almost typed CCCP, bad ole days) Here is what they recommended. The picture shows a proportioning valve, but the kit does not need it, so you don't get it. With shipping it is $332.00. http://www.classicperform.com/Store/1960_1972_Chevy_Truck/6062BB2.htm I explained that I would not like to use the booster, to try to keep close to the OEm look, they said it was not required, but recommended for stopping power. | | |
#84497 10/19/2007 9:27 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Restoring is a great and honorable goal and one I have in the past attempted. However in any area where I can improve safety I will overlook originality in favor of safety. Jake, get the booster! Now, I've done my duty...
~Jim
