0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#842646 04/09/2012 10:59 PM
1 Offline
So im trying to put a engine fan in my 53/64 truck for proper cooling. I have a few questions on trimming the fan because i think it would be the easiest way to make it fit.
My first question is, in order to clear the radiator i trimmed down the front of the fans clutch. Will that cause a problem, i wouldn't think so but just thought id ask.
My second question is the fan blades need to be trimmed about a 1" from the tips. If i cut the tips of the blades off will this cause balancing issues? or any kind of issue?
modifying a fan in any way is taking a big chance on making a hole in your hood or killing someone, find a fan that fits or get an electric pusher in front of the rad
1 Offline
Ya an electric fan was kinda what i was thinking of getting, just thought i would try saving the old fan first. Is their a certain size fan i should try to get or would a single electric fan off of a car do the trick?
I yanked a big electric fan off a mid 90's T-Bird. I've got a high compression 327 and that fan combined with an aluminum radiator cools it just fine (even when I lived in Phoenix). The fan is two speed. I have the high speed connected to a relay, operated by a thermal switch in the intake manifold. The low speed is connected to a 3 way toggle switch. Power will only make it to the high speed circuit if the toggle switch is in the off position.
Sir Searchalot
Sir Searchalot
Move the radiator forward, use electric fan or find a "thinner" clutch fan. Trimming is not an option, out of ballance= explode per red58 post.
I agree get a electric fan, it will work way better & safer too.....
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
