1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I have a set of standard sized pistons and a set of oversized pistons.
Will the rods from the oversized pistons fit on the standard piston?
On #4 and #3 the bearings spun, and I was advised to not use those rods. I was thinking of using the rods from my oversized pistons in all 6 standard ones. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Yes, the wrist pin sizes will be the same, no matter what the piston diameter is. At one time, oversize wrist pins were available, to be used by reaming the pin holes oversize, but when the engine was rebored, the wrist pin size went back to standard. Since stovebolt rods clamp onto the pins, there's no wrist pin bushings to deal with in the rods. Go ahead and swap a couple of rods if necessary. Jerry
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks Jerry - I was going to swap all 6 as I was worried about weight difference - they seem to be manufactured a little different.
Necessary? | | |
