1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | How do I get to the front sill bolt nuts so I can remove the bed from the truck? There are frame members in the way and although the bed has replaced sometime back, bhot to get to the nut to remove the bolt has me baffled. Appreciate any info.! Thanks, Tex Chev 51 | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | the frame has a triangular plate that the front cross sill bolts to.Reach in under that plate.You will feel the bed bolt nut.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Unless its modified, the long bolts should have the nuts under the frame ...pic... ...pic... Good luck | | |
