2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84412 10/16/2007 3:19 PM | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | I am wanting to switch the original 4speed trans for a 5or6 speed that has overdrive, is there some junkyard choices out there, I know it will be a newer set up and that is fine, I have 4:11 gears and I want it for a daily driver. Dennis M
Dennis M
#84413 10/16/2007 5:38 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If you are going to use your C20 as it was intended, that is as a truck; then find one of the late model 5 spds from a 3/4 ton. The Camero and S10 5 spd is not a truck trans. | | |
#84414 10/16/2007 9:10 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Lonnie is correct. The S-10 5 speed is easy to come by & there is lot,s of info in this forum about the swap. If you are going to do some heavy hauling it would not be recomended. For a driver if you don,t do burnouts or speedshifts it will work good. I,ve done 2 of them & they are fun to drive. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
