2 members (PAUL Berardi, Guitplayer), 312 guests, and 4 robots.
Topics128,081
Posts1,056,078
Members48,434
#84412 10/16/2007 3:19 PM
I am wanting to switch the original 4speed trans for a 5or6 speed that has overdrive, is there some junkyard choices out there, I know it will be a newer set up and that is fine, I have 4:11 gears and I want it for a daily driver. Dennis M
Dennis M
#84413 10/16/2007 5:38 PM
If you are going to use your C20 as it was intended, that is as a truck; then find one of the late model 5 spds from a 3/4 ton. The Camero and S10 5 spd is not a truck trans.
#84414 10/16/2007 9:10 PM
Riding in the Passing Lane
Lonnie is correct. The S-10 5 speed is easy to come by & there is lot,s of info in this forum about the swap. If you are going to do some heavy hauling it would not be recomended. For a driver if you don,t do burnouts or speedshifts it will work good. I,ve done 2 of them & they are fun to drive.
1972 Chevy c10 Cheyenne Super
