5 members (MikeStone1953, Bill Hanlon, Wally / Montana, Oswald, tesa), 162 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#84393 10/15/2007 11:25 PM
This is a first with the forum. I am wondering if there is a 5 or 6 speed trans with overdrive that will fit in place of the orginal 4 speed,I have 4:11 gears and am trying to make it more livable as a daily driver.
Dennis M
#84394 10/16/2007 4:33 AM
What motor are you running?
A T-5 will do the job running a six, but if you load it the trans might be marginal.
The Tremec transmissions are another possibility to look at, and they are pretty stout.
These are all car type transmissions, if you are looking for a truck type, hopefully the next person to respond will give ideas on those.
#84395 10/16/2007 4:42 AM
What do you use your truck for, any heavy hauling. The is no direct replacement, most trans with an overdrive are going to require a drive shaft modification. I replaced the sm420 in my 63 C20 with a a833 - aka RPO MY6, it's a 4spd, 4th being an OD. I'm hoping the trans will at least pull a car trailer. Chrysler did use the tans in 3/4 ton Dodge trucks. Another popular trans is a T5 out of a Camaro or S-10.
Larry
I don't own a vehicle that isn't old enough to drink.
