| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84393 10/15/2007 11:25 PM | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | This is a first with the forum. I am wondering if there is a 5 or 6 speed trans with overdrive that will fit in place of the orginal 4 speed,I have 4:11 gears and am trying to make it more livable as a daily driver.
Dennis M
#84394 10/16/2007 4:33 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What motor are you running?
A T-5 will do the job running a six, but if you load it the trans might be marginal.
The Tremec transmissions are another possibility to look at, and they are pretty stout.
These are all car type transmissions, if you are looking for a truck type, hopefully the next person to respond will give ideas on those.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#84395 10/16/2007 4:42 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | What do you use your truck for, any heavy hauling. The is no direct replacement, most trans with an overdrive are going to require a drive shaft modification. I replaced the sm420 in my 63 C20 with a a833 - aka RPO MY6, it's a 4spd, 4th being an OD. I'm hoping the trans will at least pull a car trailer. Chrysler did use the tans in 3/4 ton Dodge trucks. Another popular trans is a T5 out of a Camaro or S-10.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
