5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
How do I get to the front sill bolt nuts so I can remove the bed from the truck? There are frame members in the way and although the bed has replaced sometime back, bhot to get to the nut to remove the bolt has me baffled.
Appreciate any info.!
Tex Chev 51
the frame has a triangular plate that the front cross sill bolts to.Reach in under that plate.You will feel the bed bolt nut.
Unless its modified, the long bolts should have the nuts under the frame
...pic...
...pic...
Good luck
