| | | Forums66 Topics128,268 Posts1,058,376 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I wasn't sure where to post this so I decided to post it here. I have a 250ci in my 38 GMC that I want to put Langdon headers on But don't have the money, anyway I was checking ebay out and found this http://www.ebay.com/itm/320805012222?_trksid=p5197.c0.m619#ht_500wt_1048 thought it was cool. I think I am going to give it a try and see what happens.
1938 Gmc 1/2 ton
| | | | | Joined: Feb 2012 Posts: 1 New Guy | | New Guy Joined: Feb 2012 Posts: 1 | It works...Gets the job done..I got it on my '47 coupe...Doesn't look too hokey...It WILL take longer warm-up time though, losing that heat-riser , not good... | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | theres an old timer my way that splits exhaust all the time. it works. mo
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The whole point of a split manifold is to keep the heat riser intact to maintain cold start driveability. $40.00 for an elbow with no studs or bevel seems a bit steep to me as a 2" gasfitters elbow will work better and set you back about $3.00. Pre and post heat are the key to success when welding cast iron and I compiled what I did here.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Curt Thanks for the info I like $3bucks even more then the $40, I will have to find a gasfitters elbow now. I also like your documenting how it is done.
Where do you get a 2" gas fitters elbow ?
1938 Gmc 1/2 ton
| | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Your local Plumbing Supply house will have them... Mike B  | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I still see GM Chevy Corvette six and Repop split manifolds at the Swap Meets. The last one I saw still had the GM parts tag on it help by a thin wire. That one had the heat riser in it. Split manifolds work fine and if you can keep the heat riser, even better. Normbc9 | | |
