7 members (68ironhead, HandyAndy, jmoore, Rexville48, walter74, 6inarow, 1 invisible),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,567 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 17 New Guy | | New Guy Joined: Jan 2009 Posts: 17 | I got another truck a 1950 GMC and it has a 6 cylinder engine and the valve cover has GMC stamped right in the top .Has anyone ever seen this? This truck does not run and needs alot of work. 1953 GMC 9300In the Stovebolt Gallery[url=http://s871.photobucket.com/albums/ab277/silver90_photos/1953%20GMC%209300%20Five%20Window/More pix on Photobucket[/url]
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Sounds like you got an American GMC, as opposed to a Canadian GMC. Canadian GMC trucks used the Chevy 6, the GMC 6 is a superior engine to the chevy engine. If you check the horizontal pad behind the distributor, there should be a number stamped there. The first 3 numbers stamped will tell you the engine size. A 1950 American gmc would have had a 228 6 from the factory. However, a 248, 270, or 302 gmc 6 will bolt in where the original 228 was.
I'm crossing my fingers and hoping you have a 302 in there. John | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | john, i love your optimism. i know you know anything is possible when it comes to gmc engines  | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | ...the valve cover has GMC stamped right in the top .Has anyone ever seen this? Yes, it's quite common on real GMCs.  | | |
