Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TexasFarmTruck, crenwelge, Mike1933, tclederman), 227 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#842370 04/09/2012 1:29 AM
While working on updating my entire brake system, I recently had my front drums measured for inside diameter. Passenger side measured 11.139 and the driver side measured 11.102. Is this out of spec? Is the factory 11.00? The guy who owned the shop said he hadn't used that tool in a long while and mentioned that his father had worked on the "old" drums back in the day. I mentioned arching shoes and he knew of no one in town that still does that. I'll be replacing the shoes and was wondering if I should get new drums as well. Thanks
back yard wrench turner
IIRC 60 thousands over is the max allowed. Factory is 11.00. I think I would buy new ones. They are not very expensive.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Actually, I believe the oversize limit for truck drums is .090". The dimensions you've got are so close that at least one more set of brake shoes should work as long as the drum surface is smooth. If the drums are scored or out of round, don't try to machine them any bigger.
Riding in the Passing Lane
I think that is streaching it a bit. Those 1/2 ton drums are the same as a car. Ive seen them running that thin but you will have better brakes with new drums. Like Vert says, they are not that expensive & are readily available.
1972 Chevy c10 Cheyenne Super
"While working on updating my entire brake system"
Lose the front drums in favor of disc brakes. Keeping the drums is not an update!
Thanks for the info guys. I'll shop around and pick up a new set of drums. What do I use to put the hubs on the new drums? Do I just drill out the existing factory rivets?
the rivets aren't needed, frequently already gone on these old rigs - drill them part way from the inside and drive them out, or sometimes you can slam the drum down on a hard surface and the hub will come loose
