0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | How does the bell housing unbolt from the block on a 235? Already found the top two bolts but I'm not seeing any others. Just trying remove the small stuff before I scrap the rest. | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hi Slick Willy, to remove the bellhousing you have to remove the pressure plate, clutch and flywheel. Then you have access to two more mounting bolts. | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | One question for you, what year 235? Do you wanna sell the inspection cover and plate? | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | not sure what year 235, tell me where to look for the numbers and I'll post the info. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Personal buying and selling should take place in Private Messages and/or in email (check each other's Profiles). There is a code pressed into the block, just to the rear of where the distributor enters the block. Post that code and people should be able to tell you more about the engine. Here are locations for a variety of codes that can usually be used to ID an engine. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are 4 bolts under the flywheel. | | |
