9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible), 75 guests, and 0 robots.
Topics128,205
Posts1,057,427
Members48,471
I am need of replacingg the 250 out my truck (I lost all compression on the 1st and 2nd cilynder) and was wondering how much sheetmetal do I need to remove to get to it?
Most of the time I see the front clip fully removed but can I get always with removing the front grill, radiator mount and radiator?
Yes, just removing what you suggest should be good enough. It would also help if you raised the front end on jack stands too for added clearance, but that's not required.
Drew
There should be no need to remove the grill.
My Blog
So I can get away with just removing the radiator??? and pulling it forward
I have pulled a lot of 216s and 235s from those trucks and I only remove the radiator. I also remove the water pump. I also unbolt the bell-housing from the engine and leave it bolted to the cross-member. That leaves the engine short enough to clear as it comes up. Since you have a 250 there may be a slight difference.
My Blog
