1 members (Truckrolet), 154 guests, and 2 robots.
Topics128,149
Posts1,056,818
Members48,456
what setting do you set the timing light advancement on for a 228. Is it 6 degrees or 3 degrees? This is a GMC engine.Hope someone has some info.
45 gmc above the 49th
here's a chart of dizzy spec's that includes back to the fifties if it will help... the 228 is near the bottom, hope it helps
Dizzy specs
Here's the old manual project link for a 48-51 as well
48-51 manual
Give me ambiguity
or give me something else
i set mine on the ball which is 5 degrees.
Crusing in the Passing Lane
Make sure it's hot, if it ever pings, slowly retard 'til that stops.
Holy Cow. I grew up in scenic Red Deer, and went to LTCHS. It's a small world on the old interwebs.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
