3 members (RLB, Gray_Ghost, Leo),
112
Mod | | | Forums66 Topics128,140 Posts1,056,776 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 2 New Guy | | New Guy Joined: Feb 2012 Posts: 2 | Hi,
This is my first post. I recently purchased a 1954 chevy 3100 and I'm having a blast driving it around town. It's a stock truck and hasn't been modified, which I intend to maintain...however...
It has the original drum brakes and I'd like to convert the fronts to disc brakes (for safety sake).
There are numerous complete kits out there and I'm hoping someone here can recommend a kit/vendor that works well and has good installation instructions.
Thanks! Kevin | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I used the CPP kit, incl. the power booster and hanging pedal conversion. THe kit also converts from ball bearings to roller bearings. USes standard GM/Camaro rotors and calipers. Trouble free installation and good performance.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm working on a disc brake conversion for my 54 3600. It may be an 8 lugger, but I can't see any reason why it wouldn't work for the 1/2 tons. I'm using a 13" rotor and the caliper is the same as what the 99 and newer 1/2 ton trucks use. I can't see any reason why it wouldn't be adaptable to the AD 3100 trucks.
I can send some pics if you want.
Chris | | | | | Joined: Feb 2012 Posts: 2 New Guy | | New Guy Joined: Feb 2012 Posts: 2 | Thanks Squire. I see that the kit includes the power booster, but it doesn't mention the "hanging pedal conversion." Was that something additional you needed to order? Was it for a '54 3100? | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Kevin, I'm also getting ready to do some mods to my 54 1/2 ton. Are you planning on keeping the 6 lug in the front? Brothers currently has some items on sale, including the kit. I've not delt with Brothers yet so I don't know how the quality is. I'm sure someone here can comment on that. Keith | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something that you will need to consider, most, if not all, of the aftermarket disk conversions will not work with stock wheels, or at least not the 15" wheels. The caliper hits the wheel in the drop well where the center is attached.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Kevin, Welcome to the Stovebolt community.
I've been driving with the CPP 6 lug disc brake conversion fitted to my '50 3100 truck for 4 years now. I am very pleased with the braking performance, there's no noticeable fade even when braking from high speeds; brake fade was a big problem when I still had the drums at the front. I thought the disc kit was quite simple to install, although the instructions were quite basic.
The 6 lug kits from all the vendors seem to use the same components, so I'm not sure that it would make a lot of difference (apart from the price) wherever you buy.
| | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | One more thing to consider is these kits will space the wheels out so when you get new rims you can compensate with more backspace. I think all kits move the wheels out but some more than others. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Camperkev
Yes, you have two ways to go with their kits...
One is to keep the under body location and install the booster/master in that location to keep your original pedal "thru the floor"
or,
convert to a hanging pedal with the power master/booster on the firewall. Using this one you cut out the old stamped sheet metal dashboard brace and replace it with their 3/16" steel brace assembly that the booster then bolts directly to thru the firewall. Since I went with a new tilt column I decided I'd prefer this set up. It's quite stout.
Hope this helps
