2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#840919 04/03/2012 8:30 PM
My truck came with aftermarket aluminum wheels and tires. Went to put center caps on and noticed that the lugnuts were typical beveled style but the wheels use a shank style lugnut. I measured the thickness of the wheel, and searched on line for the lugs. ALL the lugs had shanks of .68 diameter. I ordered the lugs and when they arrived I found out the holes in the wheels are .62 ! No one sells .62 lugs, So the question is how to increase the diameter of the lug holes in the wheel. (If i cut the lugnuts down they will rust in the wheel). Thought about using a "hand held" adjustable reamer, but worry about getting the holes on center. It would be cost prohibitive to send them to a machine shop to have 24 holes done (even if they could figure out how to hold the wheels. Any input?????????
Did you get the nuts from the wheel manufacturer? If not, you may need to contact them in oder to get the correct lug nuts.
Another possability is that since the wrong nuts were used, the holes in the wheels may have a corrosion buildup, preventing the shanks from going in the wheel. You might see if you can clean them out if this is the case. You'll also need to inspect the lug holes for damage, as there really is no way to instal a cone seat lug on a shank style wheel without damaging the wheel. Same goes for other way around.
Bill Burmeister
Cut the lug nut shanks down in a lathe and use a little NeverSeez on them when you install them. That stuff keeps bolts from rusting on steam pipe flanges, and that environment is far more severe than anything a lug nut will ever see.
Are you sure your wheels are not suppose to use tapered seat nuts?
My blazer has factory alloy wheels and it uses tapered seat nuts.
If you know the brand of your wheels I would check with a tire store or the manufacturer on nut recommendations.
My Blog
Found the lug nut!!!!!! On ebay lol They are STEPPED Appliance stepped lug nuts!!!
