2 members (ndkid275, Phak1), 58 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#84082 10/11/2007 12:47 PM
I have a 1955 2nd truck with a worn out 235 Hydramatic combination. Is it possible to swap to a 1969 250 I6 without too much/many probs?
Riding in the Passing Lane
It,s not a simple swap but with the right equipment & knowhow it can be done effectively. You will want to use a later trans. that matches the engine.
1972 Chevy c10 Cheyenne Super
Easier to rebuild the 235.
yA'LL ARE RIGHT. That's prolly the way to go, thanks for the data and input.
Depends on what you want to do. A 250 would be an upgrade as it produces more power & is easier to modify. You could also use virtually any late model transmision as well.
Robert C.
I'm a Genius in the making.
1950 3600
