0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | My friend has a sheet metal shop and we made a bed out of hot rolled steel for my 49. My question is, what type of prep work is needed with this type of surface before painting with apoxy primer? | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Most removal of mill scale involves sand blasting, which will likely cause warpage, or an acid wash (muriatic, hydrochloric, sulfuric, etc....) which if not removed in its entirety will cause adhesion problems with paint. Hindsight and all that good stuff, why didn't you use cold rolled, or was this some steel he had laying around? | | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | MPandC, yes,you and correct,that is what he had and it was free and if its free, its for me. So a good muratic acid wash and then another wash with baking soda and water, will that work? | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I'm no expert on the subject, so perhaps some online research will yield some more definitive answers for you. I believe they call it pickling (removing the scale) but I do know that soda blasting is not a good mix for paint adhesion either, so your baking soda suggestion would also need a cleaning. Where the baking soda will likely neutralize the acid, I believe a good bath using Ivory liquid and scotchbrite will then neutralize/clean off the soda. But again, please verify with some research, I have not done this personally to speak with any firsthand knowledge. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | For what it's worth, I just asked this question of the owner of SPI where I get my epoxy from. My concern was if there is the same problem using washing soda (which is baked baking soda)in the electrolysis process as with soda blasting. He told me not to worry they react with the metal differently and Washing soda is safe to use (with SPI epoxy) though it might still be a good idea to wash with a bit of Dawn and water followed by wax and grease remover prior to paint.
He also told me in the past to make sure to remove any acid while its still wet. If it is allowed to dry to reapply the acid (phosphoric in my case) and let it reactivate the residue in the pores of the metal then wash/neutralize with plenty water. I followed that with a shop vac blow dry to minimized flash rust which worked well in my situation. (no rust even after three days in the enclosed garage.)
