| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | I just bought a 58 Suburban. At some point in its life somone installed a roof rack. It was simply screwed or bolted to the roof. Now I have 8 or 10 small (1/8 -3/16) holes in the roof. The problem is they are spread all accross the half-acre of nearly perfectly flat roof.
I know welding is normally the method for plugging holes. I'm afraid I'll crate a washboard out of the roof if not extremely careful about heat build up. By the way, I've never welded before. :-(
I was wondering if there is some kind of metal glue or epoxy. I thought I'd get small (dime size) rounds of sheet metal and glue them to the underside of the roof under the holes. I could then fill in the screw hole with a very thin coat of body filler from the top. Sand it smooth and hit it with primer until I ever get around to a finished paint job. Is this something that might work?
Any other ideas for quick fixes for the near term and more permanent solutions for the long run?
Larry
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Welding is the preferred solution that you can be sure won't prematurely wreck your paint job. If you can't do, find someone who can. Heat build-up due to welding a small screw hole is not usually a problem. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You are wise to be concerned about warping the panel from too much heat. A good welder can do it if they take their time.
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Gentlemen;
Ok, thanks. I guess its time I learned how to use a welder. How do you weld up the small hole. Do you just put a tack weld right in the hole and call it a day? I'm sure there will be some grinding involved. Do you need to use a hammer and dolly to flatten the weld out?
I'll have to track down an old hood or something else large and flat. I drill a bunch of holes in it and practive welding them up again.
Larry
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | This would be perfect for your roof hole welding project: Magnetic Copper Backing Plate SimS | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Robert: Simply amazing....
I have found great success in just spot welding holes closed. I start at the edge of the hole and place a "spot" of weld. I simply repeat this process until the hole is closed. On small holes, I do it all in one pass. On larger holes, I do two spots and let the metal cool before proceeding with two more and so on.
Finally, the weld is ground down smooth. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Sims;
Thanks for the tips. The magnetic copper backing plates look very interesting.
MP&C: Where did you get the small punch to make the holes. It looks like it would be perfect for my requirements.
David:
I may try the simple spot welding technique to see how that works.
Larry
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Roper Whitney #5 hand punch, they are available new all over the net for around $80-90, mine I picked up used for about 20. Kinda hard to justify buying one just to fill a few holes, but you can also cut them out by hand, just is less precise and more tedious. http://toolmonger.com/wp-content/uploads/2008/10/0927102-11.jpg If you have any sheetmetal shops nearby, or automotive body repair, they may have one where they could punch out the plugs for you. The factory sheet metal should be 19 ga, in Europe, 1mm is about the same equivalent thickness. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | While not as good or permanent as welding, JB Weld works well also.
On that metal, as long as your machine is set up right (amperage), get a copper welding spoon, or just take a piece of copper water pipe, hammer one end flat, put a crook in it, and hold it against the back. for that size of hole, should take no time to weld and very little heat transfer.
You can also get a product that will absorb the heat away from the metal. It is reusable and looks a lot like modeling clay. use a flap disk to smooth off the weld and get it. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | If you are concerned about the warpage.... how about attaching your small sheet metal patches with the 3M auto body repair adhesives that they market...?
Body shops are using this stuff for major body repairs and manufacturers are starting to use it,too. They replace whole quarter panels with it, so I suspect it would be just fine for attaching your little hole patches. Then just skim coat the repaired hole and feather it in as normally done..
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | x2 on the 3Mpanel-bond. Sheetmetal will tear before that panel-bond lets go-it's amazing stuff. | | |
