1 members (baldeagle),
70
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | My 53 half ton came without the outer grill strips. The rest is intact. I came across the pieces I need but in order to install them, it looks like I need to remove the radiator, pull the existing grill and attach the new strips and reinstall the unit in one piece. The engine is still in place. Is there an easier way? Thanks Steve | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I'm not sure if this will help or not, but it's pretty easy to just remove the front clip. 7 bolts on each side, 2 top supports and 2 bolts on the front bottom. The advantage is you can set the front clip on saw horses and get other things cleaned up while it's off.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | No need to pull the radiator ...link... Maybe the pics above will help | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Well, that sure sounds a lot easier than my idea! Thanks, Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for the great pics. This really makes it easier to understand. Like they say, a picture is worth...well you know. Steve | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Good reference and great pics
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | |
