7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#839280 03/28/2012 4:50 AM
Does anyone have pictures of a spare tire rack and how its mounted on a 1964 chevy long bed step side, Im trying to rebuild my dads first truck back to as close to factory as possible... Also being that it is a long bed step side and this rack is made for the outside of the bed, does it need to have a notched fender??
Thanks for any help!
Brice Layne Loganbill
You mention "as close to factory as possible"... here is a photo of the stock "factory" set-up with the notched fender on a longbed stepside.
http://inlinethumb33.webshots.com/48544/2699912630103882008S600x600Q85.jpg
In regards to needing the notched fender I'd suggest setting a tire on the step and seeing if there is enough room, kinda depends on the diameter of tire you are running.
You could make your own bracket, I fabricated one out of structural steel for my shortbed shop truck.
http://inlinethumb40.webshots.com/28711/2886424430103882008S600x600Q85.jpg
http://inlinethumb12.webshots.com/49611/2743143930103882008S600x600Q85.jpg
http://inlinethumb08.webshots.com/50311/2375730440103882008S600x600Q85.jpg
Thank you for your help and advice, Ive grown up working on and around cars, but learning as I go with this build. Gotta love working on these old trucks
Thanks again!
There is a bracket on eBay.
Side Mount Spare Tire Bracket for Long Bed Fenderside http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300685210030
1964 GMC K1500 4x4
F. L. Anderson Fire Truck
More pix on Photobucket
