2 members (Bill Hanlon, JW51),
97
Mod | | | Forums66 Topics128,154 Posts1,056,861 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | could i use 16 on the front turn in side out?? regards r.j. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Won't work. What are we turning inside out?
| | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | i want to put the wheel on the opposite way it should go on, just thought i ask. the dish will not work with the 16 put on the right way. i cant find any 17 used tires as of yet in my area regards, r.j. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Aren't those lug bolt holes tapered from outside in? There is your centering of wheel and tightening. Also turning rim around screws with your "Back Spacing". I have been wrong before but I dont care to meet you coming at me on the highway and your driverside wheel comes off and at me. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No, you are correct. There are some wheels that are made to be mounted either way, but those are pretty much all Agricultural or racing wheels, and are designed to be able to be mounted in either direction for track width adjustments.
Bill Burmeister | | |
