| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 18 New Guy | | New Guy Joined: Feb 2012 Posts: 18 | 1950 3100. Antique radio picked up at Pomona at least 10 years ago. When radio is powered up buzz-humm is all that comes through speaker. Vibrator, caps, filter problems? Any help appreciated.
Kurt | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Well it is a good sign that there is life. I would suggest replacing all the capacitors to avoid doing any damage. What you are most likely hearing is the buzz from the power supply that has dried out electrolytic capacitors. In general it is usually not worth the time trying to diagnose problems until all the capacitors are changed. | | |
