7 members (Lightholder's Dad, Otto Skorzeny, KEVINSKI, lumbersawyer, BC59, tclederman, 1 invisible), 67 guests, and 1 robot.
Topics128,154
Posts1,056,853
Members48,456
#838780 03/26/2012 4:37 PM
Q
QX
Offline
Q Offline
could i use 16 on the front turn in side out??
regards
r.j.
QX #838899 03/26/2012 11:23 PM
1 Offline
Won't work. What are we turning inside out?
Q
QX
Offline
Q Offline
i want to put the wheel on the opposite way it should go on, just thought i ask. the dish will not work with the 16 put on the right way. i cant find any 17 used tires as of yet in my area
regards,
r.j.
1 Offline
Aren't those lug bolt holes tapered from outside in? There is your centering of wheel and tightening. Also turning rim around screws with your "Back Spacing". I have been wrong before but I dont care to meet you coming at me on the highway and your driverside wheel comes off and at me.
No, you are correct. There are some wheels that are made to be mounted either way, but those are pretty much all Agricultural or racing wheels, and are designed to be able to be mounted in either direction for track width adjustments.
Bill Burmeister
