1 members (Hush),
73
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | Uh...what the heck is this sticking out of my exhaust manifold. And what did it do? See pic here. This is on my '69 L6 C-10. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Its the counter weight on the preheater that is spring loaded. when cold it tightens up and closes the exhaust off directing the heated air back into the intake, when things warm up it opens and allows all the gasses out the exhaust pipe.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It's called a heat riser,it opens and closes a valve in the exhaust manifold to warm up the intake manifold and the carb so they don't freeze up when the engine is cold and the air is cold. That coil is like a thermostat and and is whats called a bimetalic coil it will coil tighter and looser when it cold or hot.The iron thing you see is the counter weight so the spring does not have to work that hard to open and close.Most of the time they are rusted and don't work ,but you should get it to work right.I took mine and tapped it lightly with a small hammer and keep trying to get it to move and at the same time sprayed it with liquid wrench it took about a week to get it free than I bought a new spring coil fron Clasic of America now it works .
Pete | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | Thanks, guys. I found it yesteday when I was feeling around for a nut I dropped. When I touched it, it moved and I thought, "What the heck?!?!"
Pete,it actually turns freely. Thanks for the vendor tip. | | |
