| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Will a rocker assy that says it's for a '41-'58 235 work ok on a '59 235 engine? What's the difference? Darren | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are no rocker assemblies that span that many years. 1954-58, and 1959-62 for complete assemblies is correct. 1954-58 rockers have a groove inside each rocker that is centered. 1959-62 the groove is offset 1/4" from center. If you use the rockers with centered grooves on 1959-62 engines you will get to much oil out of the vent holes on each rockers. This can be over come easily if needed.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | So if I use the older oiler tube that has the extra tube with the crimped end it should be OK? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1958 and earlier should not have a crimped tube but there is more to it than just that. Up through 1958 the engines had a 1/16" orifice restricting the flow of oil to the rockers. Starting in 1959 the orifice size was increased to 11/32". This larger orifice offered almost no restriction. At the same time the overflow tube on the rocker connector was pinched off. Also at the same time the groove inside each rocker was offset 1/4" so it did nit line up with the supply hole at each rocker. This prevented oil from squirting out of the vent hole on each rocker. If you use 1958 or earlier rockers on a 1959-62 engine you will have the best luck if you restrict the oil supply. Chev did this on replacement short blocks by selling you a plug to put in the block to block the original oil path and a special drilled head bolt drilled with a 1/16" hole for the oil to pass through.
On 1959-62 engines I work on that have 1958 or earlier rockers I install my own orifice, a 5/16" OD plug, .400" long, with a 1/16" hole drilled through the center in the head under where the rocker supply tube fits in the head. I then use a rocker connector with the overflow tube.
