2 members (Peggy M, panic), 89 guests, and 4 robots.
Topics128,030
Posts1,055,428
Members48,422
#837752 03/22/2012 11:06 PM
I need some cork gaskets for my glass bowl on da fuel pump on my 41 chevy 1/2 ton. Any good sorces.?? thanks
Go to the parts store and buy some gasket material and cut your own, that's what I do.
Bruce
My Trucks
Stuff I Collect
what he said above X2
Give me ambiguity
or give me something else
CASO #837894 03/23/2012 11:08 AM
if you don't want to cut them jim carter has them, most likely chevs of the 40's. they don't cost much.
If you cut your own gasket from FLAPS cork gasket material ...
I found it best to draw your gasket on paper. Attach some blue painters tape to the gasket material. Then attach the paper pattern to the blue tape with spray adhesive. The tape is a lot easier to remove from the cork than the spray adhesive.
I cut the cork with a single edge razor blade.
Replace the gasket anytime you empty the bowl. See lower right corner of this "Cadillac Serviceman." It will turn into a cornflake if it gets dry, and it won't return to round and flat when it gets wet again.
Classic Truck Parts, Jim Carter, Chevs of the 40s, and The Filling Station sell a gasket for glass bowl pumps.
- Lonnie
My '54 3104
