| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 12 New Guy | | New Guy Joined: Dec 2011 Posts: 12 | I have a 1953 GMC, 5 window 1/2 ton pickup that I am slowly working away at. I have removed the box and began body work on it. I have also removed the torque tube and rear end out of the truck for tear down and rebuild. One I opened the rear cover I was greeted with rusty slime and water. Any thing in the slime was ok but anything above is got some rust on it. All this from a broken vent cap. Also the 17T axle splines are almost worn right out.
So when is pitting on the gears bad enough to cause fatal damage to the differential? I have spent countless hours searching this forum with little answers to my next questions. What is the easiest way to save this rear end, either with a different 3rd member, another 53 torque tube rear end (hard to find a good one in canada), or a complete axle swap?
I would like to keep the truck as original as possible but i am open to modifications if original parts aren't available.
1953 GMC 9300, Five window 1/2ton
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Any 48-53 1/2 ton GMC/Chevrolet-truck rear-end should be a match.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | What is the easiest way to save this rear end, either with a different 3rd member, another 53 torque tube rear end (hard to find a good one in canada), or a complete axle swap?
I would like to keep the truck as original as possible but i am open to modifications if original parts aren't available. Torque tubes are easy to find In Alberta but do you really want to save it as original and not be able to keep up on the highway? A 3:55 gearset can solve that though and although not the least expensive I'm happy I went that route.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Dec 2011 Posts: 12 New Guy | | New Guy Joined: Dec 2011 Posts: 12 | Hmmm... ...guess i haven't looked int the right places then.
Problem is all my gears are rust pitted to a certain degree. I was thinking of doing the 3.55 gear set till I saw the rest of the gears
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If your side gears are pitted, I would definately start looking for another center section. I also see that you have some concerns about your axle splines too. I think the best way to go, is a whole other axle. There's always guy out there that are getting rid of the torque tube and going to an open driveline. Shouldn't be that hard to find.
You could convert to an open driveling also. You'll need an open driveline rearend. 55 on up trucks had open drivelines. Also 4x4 1/2 ton trucks from the 80's used 6 lug axles. You'll have to get an open driveline transmission and driveshaft to fit the new axle though. | | | | | Joined: Dec 2011 Posts: 12 New Guy | | New Guy Joined: Dec 2011 Posts: 12 | Well Curt B. was right. I just bought a complete chassis that was rebuilt from a 1950 GMC Pickup for way less than what it would have cost me in money and time searching for parts and rebuilding it all. Now just body work remains on my '53. Thanks for all the help!
