3 members (Gray_Ghost, Mike34, Otto Skorzeny), 91 guests, and 3 robots.
Topics128,048
Posts1,055,664
#837490 03/22/2012 2:19 AM
i know this has been posted somewhere,but i would like to ask again..has anyone used the crank shaft,rods,pistons out of the 292 and put into the 250? i happing to have 250 in my truck at this time.would the extra cubes&horse power be worth it.???
The 292 has a much taller deck, that will never work. There are other ways to get more power out of a 250, pick up the Chevy Inline Power Manual for ideas. Pistons that aren't designed for running something horrid like 83 octane gas help a lot, as do upgraded cams.
1954 GMC De Luxe COE
Haven't done it. I have read that Clifford Engr. at one time had a very expensive kit to do it. There is a lot of machining that will have to go into the block. This project comes up every once in a while. The usual comments are too expensive for what little is to be gained.
Larry
I don't own a vehicle that isn't old enough to drink.
307 Chevy V-8 pistons fit the 250 as a direct swap. They're flattop, while the 250's have a big dish in the piston crown. The head will also take a .050" milling job without getting into piston/valve interference problems. Combine those mods with a somewhat hotter cam, something in the 270 degree duration range, and it makes the 250 come alive.
I have a nice set of .020" over 307 pistons socked away for that project. Four valve reliefs instead of a big dish should significantly help the compression.
