| | | Forums66 Topics128,047 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i know this has been posted somewhere,but i would like to ask again..has anyone used the crank shaft,rods,pistons out of the 292 and put into the 250? i happing to have 250 in my truck at this time.would the extra cubes&horse power be worth it.??? | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The 292 has a much taller deck, that will never work. There are other ways to get more power out of a 250, pick up the Chevy Inline Power Manual for ideas. Pistons that aren't designed for running something horrid like 83 octane gas help a lot, as do upgraded cams. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Haven't done it. I have read that Clifford Engr. at one time had a very expensive kit to do it. There is a lot of machining that will have to go into the block. This project comes up every once in a while. The usual comments are too expensive for what little is to be gained.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | 307 Chevy V-8 pistons fit the 250 as a direct swap. They're flattop, while the 250's have a big dish in the piston crown. The head will also take a .050" milling job without getting into piston/valve interference problems. Combine those mods with a somewhat hotter cam, something in the 270 degree duration range, and it makes the 250 come alive. Jerry
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I have a nice set of .020" over 307 pistons socked away for that project. Four valve reliefs instead of a big dish should significantly help the compression. | | |
