7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | Have rebuilt my 248 six cylinder and it will not start. The problem appears to be no current/spark/whatever is coming through the wire from the top of the coil to the distributor. Its a new coil and ballast resistor. All wiring appears to be OK. Any ideas? Thanks/Lee | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy smithleej, are the points opening and closing, are they clean and not burnt, are they adjusted properly??? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | Points are new; are opening and closing and believed to be adjusted properly. Timing is also believed to be adjusted properly. | | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | With the ignition on, power is getting to both the plus and minus side of the coil. I guess the question is, what would cause the no spark condition when you hold the high tension wire from the coil to ground and crank the engine?? Thanks | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | With the points closed, there should be no measureable voltage at the (-) side of the coil. It sounds like the circuit through the points is not getting completed for some reason, either incorrect connections inside the distributor, or the distributor housing failing to get a ground. Points open- - -battery voltage at the coil (-), points closed, 0 V. at the coil (-) terminal. If it's not doing that, the coil can't develop a spark. Jerry
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Might be a dumb thought ...but does the engine block have a good ground? Might try a new Coil.
....David
| | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | I appreciate everyone's help. Heres the latest...the distributor has good ground and battery voltage at the coil with the points open and no voltage with the points closed. I guess its back to the books....the coil is new. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is really a simple setup. I assume that "holding the high tension wire to ground" means leaving a gap. If you don't have a gap, there will be no spark. I like to connect a spark plug wire into the coil, attach the other end to a spark plug and sit it on the valve cover. That way I can check for a healthy spark. I know that if the condenser is open, it will generate almost no spark at all. | | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | Again, thanls for all the help. I do now have spark from the coil. All of the electrical seems to check out. Now I guess its on to the carburetor. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The engine will start without a carburetor. I'm still guessing it's out of time. | | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | +1 on the timng. When I got my 248 back we installed the dist. at the engine shop, turns out we were one tooth off on the dist. It did start, but ran terrible. Once we got it in correct, different engine completely. Good luck 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
