9 members (jupitor, Lightholder's Dad, GMCJammer51, J Lucas, JW51, Tinker5, TUTS 59, wilbur53, 3B),
229
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | So i have a 8v battery that i can get for free never had acid put to it, as it is not im still doing body work on my 53 gmc 5 window, but i'm on a tight budget. So heres my question. i know 12v is the best option but can be pricey. my truck starts great and runs great with the 6v system in place now. What i would like to do is put a 8v battery and a 6v alternator and be able to get rid of the pesky regulator that could cuase me problems. has anyone done this? will it work??? thanks guys Josh
Josh
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Why do you want an 8v battery if your vehicle works fine with a 6v battery?
| | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | well its free thats a good start, but a old timer said that they used to put 8v's in his old trucks to help it crank faster and my 6v battery is from the 60's and doesn't work anymore only reason i know it works on 6v is I borrowed a 6v out of a 48 8n ford tractor but that needs it more then my truck
Josh
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | An 8 volt battery is a solution to a nonexistent problem. The voltage regulator will have to be set to 9.5 volts to charge it, and a "6 volt alternator" would have to have a custom-made solid state regulator to achieve that voltage. Your "free" battery will end up costing you about a thousand dollars to build a one-off charging system to keep it charged, and headlights and other 6 volt items will have a drastically shortened lifespan. You'll also need a custom-specification ballast resistor to keep from burning out the points on a regular basis. Good luck! Jerry
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Keep the 6volt system. make sure all the connections are clean and tight, and that you have large enough battery cables for cranking.
Those 6 volt systems work well when properly maintained. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I agree@!! Keep the 6volt system. make sure all the connections are clean and tight, and that you have large enough battery cables for cranking.
Those 6 volt systems work well when properly maintained. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'm another 6v enthusiast. In fact, I've only had six volts for daily drivers for 4 years now, and no troubles. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | They dont make 8 volt light bulbs and 6 volt bulbs dont like 8 volts., enough said? Jerry
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | My truck had an 8v in it when I got it. Now that everything is cleaned up and the timing is spot on the 6v actually works better. | | |
