3 members (Gdads51, Gib70, 1 invisible), 86 guests, and 0 robots.
Topics128,078
Posts1,055,935
Members48,430
#836522 03/19/2012 3:42 AM
So i have a 8v battery that i can get for free never had acid put to it, as it is not im still doing body work on my 53 gmc 5 window, but i'm on a tight budget. So heres my question. i know 12v is the best option but can be pricey. my truck starts great and runs great with the 6v system in place now. What i would like to do is put a 8v battery and a 6v alternator and be able to get rid of the pesky regulator that could cuase me problems. has anyone done this? will it work??? thanks guys
Josh
Josh
Nielsen #836531 03/19/2012 3:53 AM
Why do you want an 8v battery if your vehicle works fine with a 6v battery?
tclederman #836533 03/19/2012 3:59 AM
well its free thats a good start, but a old timer said that they used to put 8v's in his old trucks to help it crank faster and my 6v battery is from the 60's and doesn't work anymore only reason i know it works on 6v is I borrowed a 6v out of a 48 8n ford tractor but that needs it more then my truck
Josh
Nielsen #836535 03/19/2012 4:08 AM
H Online: Content
An 8 volt battery is a solution to a nonexistent problem. The voltage regulator will have to be set to 9.5 volts to charge it, and a "6 volt alternator" would have to have a custom-made solid state regulator to achieve that voltage. Your "free" battery will end up costing you about a thousand dollars to build a one-off charging system to keep it charged, and headlights and other 6 volt items will have a drastically shortened lifespan. You'll also need a custom-specification ballast resistor to keep from burning out the points on a regular basis. Good luck!
Keep the 6volt system. make sure all the connections are clean and tight, and that you have large enough battery cables for cranking.
Those 6 volt systems work well when properly maintained.
Roy Rodgers #836542 03/19/2012 4:17 AM
I agree@!!
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
DMGfifty #836615 03/19/2012 3:30 PM
I'm another 6v enthusiast. In fact, I've only had six volts for daily drivers for 4 years now, and no troubles.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #836662 03/19/2012 7:22 PM
1 Offline
They dont make 8 volt light bulbs and 6 volt bulbs dont like 8 volts., enough said?
My truck had an 8v in it when I got it. Now that everything is cleaned up and the timing is spot on the 6v actually works better.
