2 members (parklane410, 78buckshot), 60 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#836499 03/19/2012 2:29 AM
Looking for a 261 to put in my 54 3100. Any recommendations on what year(s) engine I should be looking for? Planning on swapping the 3 sp out for an automatic.
Also, any recommendations on upgrade to engine during the rebuild to get a bit more HP? Not looking to build a race engine, but since I'm going to rebuild it, I may as well try to squeeze a few more horses out of it.
Ive got one of the early 261's, '54 & 55 1ST with the short high mount pump. You can also install a 55 2nd - 62 with an adapter plate to install the original water pump.
Later engines have full - flow oil filters but older blocks can be converted to full flow filration easy enough when torn down.
BC
1960 C60 pasture art
BC59 #838270 03/24/2012 7:11 PM
1 Offline
This should be a no hassle swap. Like BC59 says there are few minor changes but this engine (261) came stock in the 4400 series which is the same cab with a different front fender. Our fire department still owns a '57 Chevy 5500 with the original 261. We have done some upgrades but it still starts and runs like a champ.
Normbc9
